AB Powerflex 525 faults Type1 and Type2
Tom Kazakoff
May 2004
Boulder Creek, Ca.
26
The VFD has a catagory of errors called TYPE 1. Evidently these are not serious or fatal errors. There are two parameters that allow you to have the VFD retry after a delay when one of these errors occurs.
Problem1: What does the VFD do if the retries for Type 1 errors is exhausted and the error still exists? Does it shutdown? If a motor is running does it shut it off? This is important to know for the error handler I need to write.
Problem2: Type 2 errors I think, do not allow for any VFD retries or self correction. I think they are more serious. Same questions, what does the VFD do when it gets a type 2 error? Does it turn off the motor? Does it shutdown?
Problem3: How can I get the current error from the VFD when it occurs? Is there a list of type 1 and type 2 errors somewhere?
If anyone knows about these issues or can direct me to a link or document that will answer these questions, I would appreciate it very much.
Thanks,
Tom Kazakoff
Trevi Systems
Good Evening , After running for 2 years , I have a few Powerflex 525 drives faulting out with a F 73 Ethernet Fault . What have you guys...
2,598
Continuously getting over voltage faults on our 525 Drive when NOT running. I have increased the DC voltage parameter, installed reactor on line...
7,320
Hello Everyone, I have an application using a 525 on ethernet and the safe torque off wired through an Allen Bradley CAT3 Safety Circuit. The S+...
45,961
I have 4 AB powerflex 525's in our system. I need to write an error handler that will field the faults that the VFD can get. There are many...
3,376
All, I have a PowerFlex 525 driving an agitator motor. The goal is to have the agitator start automatically after a power loss or a comm loss. I...
67
