AB PowerFlex 525 Faults
Tom Kazakoff
May 2004
Boulder Creek, Ca.
26
I have 4 AB powerflex 525's in our system. I need to write an error handler that will field the faults that the VFD can get. There are many faults, some of which are not critical. What I need is a list of faults that are serious enough to warrant a system shutdown, and perhaps an example of how to get the faults from the VFDs. Has anyone done this before?
Thanks Much,
Tom Kazakoff
Trevi Systems
Good Evening , After running for 2 years , I have a few Powerflex 525 drives faulting out with a F 73 Ethernet Fault . What have you guys...
2,597
Continuously getting over voltage faults on our 525 Drive when NOT running. I have increased the DC voltage parameter, installed reactor on line...
7,320
Hello Everyone, I have an application using a 525 on ethernet and the safe torque off wired through an Allen Bradley CAT3 Safety Circuit. The S+...
45,957
The VFD has a catagory of errors called TYPE 1. Evidently these are not serious or fatal errors. There are two parameters that allow you to have...
3,477
All, I have a PowerFlex 525 driving an agitator motor. The goal is to have the agitator start automatically after a power loss or a comm loss. I...
67
