controlconcepts
I have 2 Panel View 1000's That I got off Ebay. Great deal lol. They work just fine were form a GM Plant. The only thing that is wrong with them is they both are Humming almost like a panel alarm buzzer that got covered in tape to reduce the volume. It sounds like it is coming form the power supply area. I googled it the few results that came up was another PV 1000 Popped up on Ebay from a different seller stating the same thing that it worked fine but had humming from power supply. Is this a common thing as they get older? Should I be concerned about a failure? Any tips as to fix the issue?
Model Number
2711-TC10C20 FRN 4.2-4.XX
Thanks to all in advance.
Model Number
