AB read datalog from memory card
Holmux
Oct 2013
Aalborg
279
Dear all
I have a compactlogix 1769-L24ER where I log some production data and alarmlogs on the memory card, I store 7 days of data deleting the oldest when writing to a new file.
Everything works great, so if I am called out to a problem on site I just pop out the memory card and make a copy and check if their story matches what actually happen :)
Now this is a great tool, but I would really like to be able to access this memory card remotely and collect the files, without having to spool the files true code in the PLC to access the data, is there an easier way or more direct way to access the memory card or is this sealed off do to security reasons ??
Regards
Holmux
Hello, I am currently in the middle of a project and looking to read data from a .csv file on a server. I need to read this data and get it...
6,963
Hi, The hardware is: Click Plc model # CO-O1DD1-O HMI model # S3ML-R magnetic-inductive flow meter model # FMM100-1001. I will set the flow meter...
146
Is there a way to use the FAL instruction to do +=2 instead of +=1? I have an array that is organized with alternating "data" and "flag" values...
126
Hi everyone i have a customer, who wants to show an alarm on the machine, if the I/O forces are enabled and set, on at ControlLogix L81E with...
250
Hi Iam using monitouch hmi(V9 soft) with omron plc cj2m (CX programmer). In this I want to read a data from hmi to plc. The data was like...
99
