AB RTD card problem
juanmdx
May 2007
SLP
281
Hi everyone,
I'm working with an 1746-NR4 card (4 analog channels to read RTD), and channel 1 and 0 had been working really well for a long time.
Then I needed to use also the 2nd (or 3rd) channel, but when I connect the RTD to it they do nothing, I already checked the sensor and it is ok.
Then I changed one of the other sensors (the ones that where on 0 and 1) to channel 2 and still doesn't work, I'm begging to think that the card is damaged on the channels 2 and 3 but I also think that is really immprobable and rare...,
Do you think cards can just dammage (the plc have been working for years on the machine without problem), or do I need to do somenthing extra so that channels 2 and 3 can read?
Juan
Have you enabled the channel? ( I/O configuration )
See Pic
Good Morning , I have a RTD , that I would like to wire into a 1756-IF8 Analog Input Card. Would you all a simple wiring diagram , of what...
1,207
I had a question with regards to an Non-Isolated vs Isolated RTD Input Card. This would be for a Flex 1794-IR8 vs Spectrum (1794sc-IF8U or...
1,795
Hello all. Is it possible to run an RTD to an Compactlogix Analog input module, without any sort of a signal conditioner or anything like that? Thanks
2,220
Hi forum users. Long time lurker and first time poster here. I am struggling with an issue with the Allen Bradley 1797-IRT8 Series A Card at the...
5,845
Hello all, I've never worked on these style of cards for the Allen Bradley PLC 5. Our digester temperatures are RTD style Temp probes through...
2,772
