Hey guys, great site you got here!
I have a slight problem and was wondering if any of you ran across this before....This has been going on for a few days now. Around 6 times within a 24 hour period, the PLC will drop out of run. The fault says "specialty I/O module in slot 10 has generated a generic fault. The card fault bit is set (1) in the modules status byte." The card is 1746SC-INO4vi, an analog output card using 3 outputs going to 3 freq. drives.
Is there any way to further troubleshoot this problem? Any help will be greatly appreciated.
Thanx in advance,
DJ
Thanx in advance,
DJ
