AB Socket Open Error
Claus Nielsen
May 2016
Varde
Hi all,
Having some issues with socket connections on a 5069-L306ERMS3 guardlogix and tech support have not been able to help me so far. I'm trying to communicate with a Panasonic LP-Z series laser marker. There's already a functioning connection on this machine, it's just controlled from another PLC, a 5069-L320ERMS2 which is working fine. I tried to communicate with the existing laser marker instead but I'm getting the same error. I can't see the difference between the working code and my code.
After creating the socket the open socket will change to enabled and then to error after the specified timeout with this information:
Error Code: 16#00ff, Extended Error Code: 16#0000_0044
I've not been able to find out exactly what this extended error code means and there's only a single technote about it, but it only goes through some stuff I already did.
Anyone with any ideas?
Link to images
Currently 32.013. Just downgraded it today to use the same revision as the PLC with a working connection. It was initially 33.011 but I upgraded it yesterday with tech support to 33.012. I get the same error in all cases.
I would like to communication with application installation in my printer server via TCP port 5450. i.e ., 71.16.40.200:5450 . How can i write...
426
Trying to get a connection from siemens s7 1500 cpu to PC over tcp Using hyper terminal on PC to see if connection can be established anyone...
3,534
CIP Generic access to the Open Socket interface on the MicroLogix 1400 Hi guys, Looking for some help on getting 1 socket opened for a ethernet...
5,678
Hello! I am new to PLC programming and am required to interface a Symeo radar with a CompactGuardlogix L45s PLC. The Symeo radar uses tcp/ip...
26
5,676
Hello, I'm having an issue with creating a socket using a message instruction. I've attempted to copy the data structures from sample programs...
3,820
