ABB CS31 - How to upload program
Murphy87
Jan 2013
Saint Junien
Hello,
One of our customers has several machines equiped with ABB CS31 plcs. We have KT92 and KT93 types. I have tried to upload the program from an KT92 to see how it works. I have used 907 PC 331 under windows. The transfer start but can not be achieved, each time I tried, I got an "read error at word number 1912" message and the transfer is stopped with an uncomplete upload.
So I wonder now if I have used the the right software ? if yes, should it be used under Windows or on a true DOS machine ? at last I have some troubles to get some informations about ABB plc in France, specialy for the cable needed. I have made one with a drawing I found on Internet but i'm not sure it's the good one so if someone has the correct drawing please let me know.
JC
You can find some information on uploading software from these PLC's from this forum page:
http://www.plctalk.net/qanda/showthread.php?t=6402&highlight=abb+cs31
It seems it's not possible to upload the entire running logic ladder from the PLC.
For cable pinouts maybe this document will help you:
http://www05.abb.com/global/scot/scot209.nsf/veritydisplay/8508d45cac5706f3c1256c310032a639/$file/fptn440004r2001.pdf
Could you please help us to find CS31's programming software
907 PC 331. We have some troubles with the same PLC's.
Dear All, I have build and HVAC control system for a big shoping mall, based on ABBs AC500 and using the CS31 bus. The air handling units (AHUs)...
4,965
This is as basic as it gets, but has anyone have any experience with the 90 series ABB PLC's which is there "brick" model? They use AC1131...
3,485
does anyone have an install or know if/where i can download it for the following "ABB PS501 Control Builder Plus V2.3 " the software was a free...
106
Hello, It is mandatory to use VFD IF i use IE5 electrical motor? What happens If connect it directly as delta without VFD? Please look at motor...
156
Hi hoping someone can assist me with current issue I am experiencing with an ABB drive. Problem I’m experiencing is a ABB drive supply a large...
219
