ABB drives control panels (A,B,C,D) difference? Panel response lagging..
Jim_cz
Sep 2011
Sydney
25
Guys, does anybody know the difference between various control panels for ABB drives? I couldn't find any explanation on ABB site apart from that info that they can be used with the same drives (at least A and C)
I have a control panel that is very "slow", the response when you press a button is lagging. I'm wondering if there is something wrong only with the panel or the drive itself?
The control panels only work on drives they were designed to work with. Usually only means a drive can use only one model of control panel, except in the case when there is a "basic" and "advanced" version. Your issue could be in either the drive or the control panel. Only way to find out is to get another control panel. What drive and what control panel are you using?
Hello All, This is not a PLC question. I deeply apologize for that but I am looking for help from great members like DickDV and others. I am new...
4,816
I'm currently desigining a project that will have a few drives connected to a control logix PLC. I will be connecting to the drives and...
10,565
Has any body any experience of ABB ACS800 drives and fieldbus control? I have looked at the diagram in the manual (attached)and there doesn't seem...
5,864
I have an ABB ACS580 drive with an FEIP-21 communications module. It is currently configured with an IP address and I have verified communications...
1,609
I am using a Red Lion DA30D Gateway to control 12 ABB drives via RS485 from a M580 PLC. I send -20000 to 20000 as the speed Setpoint to each...
2,345
