about basics
PLC
Hi Amarjeet
basically Microprocessor is only CPU doen't have PORTs
and Microcontroller is having Ports, if take case of 8051 its having 4 ports
so PLC is Upgratded version of Microcontroller
feel free to ask any question
Sandeep
PLC ckt dia using Microcontroller
Thank you ,Sandeep.
But, I have read in books that plc is a microprocessor based device.
Also ,some seniors have told me that it is a microcontroller based device.Thats why I have asked this question.
Please, send your views.
My english is not so good, it may have grammatical mistakes so plz neglect it .
Thank you.
Who cares? As long as it does what we want it to do it doesn't matter what's in the heart of the PLC.
I have seen PLCs based on microprocessors as well as based on microcontrollers. PLCs based on microcontrollers are mostly brick types with no or very limited possibilities when it comes to adding extra IO. Most modular PLCs I've seen are based on microprocessors. Simatic S5-100U for instance is based on 8080 and it's derivatives. The S5-95U is based on a 80C32 or something alike. This is essentially a microcontroller (it has ports) based on the 8080, which is a microprocessor (it has no ports). So where do microprocessors end and microcontrollers start? This is sometimes vague.
Kind regards,
Hello amarjeet patil
You could learn more about PLC either from the "Learn PLC" icon on the top menu of this webby, or you could understand it from this link .
To learn about the 8051 microcontrollers, it's from this link .
Hope these will enlighten you.
I think the 8051s does not apply to what you are asking though...but doesn't hurt to learn a little more extras. MCUs are pretty fun to play with.
"blah blah blah..."
s
Hi amarjeet
See processor Evoultion is started with applcation of 8085
but for it u have to interface 8255 PORT chip so Microcontroller is a devices having all in One (basic level)
as We go further u Find their are processors which haveing More counters, Timers supports more data types , so as a Custom built application u need a such device which is comabtible with Industrial Devices
u can surf PLCS.net for basic of PLCs or search for Logixpro sim
Thanks and regards
Sandeep Patil
I'm trying to use a MOVE function as part of a sequence on Siemens S7-1200, but the program control isn't doing what I need. MOVE in TIA Portal...
1,796
On siemens when you have V15, 16, and 17 on the TIA portal is it like Rockwell where the version and firmware in the controller must match or can...
2,987
Hello! I'm a complete beginner to programming and i have a project i'm working on in TwinCAT 3 since i'm using a Beckhoff PLC. One of the...
2,357
Good afteroon, I am new to programming Panelview plus 7 using Factory talk from AB. I successfully uploaded the .mer file from an HMI screen. I...
6,342
anyone got an recommendations for books, websites, blogs, whitepapers, whatever that cover panel design best practices? the short of it is, im a...
1,723
