about mpi and profibus
MPI = Multi Point Interface
Profibus = Professional Field Bus
Both are based on the RS485 electrical standard.
MPI is used for programming the PLCs and, in a more limited way, communication between PLCs. The speed is normally limited to 187,5kbaud.
Profibus: is used for communication. Depending on the version, (DP, FMS or PA) the type, frequency and length of the messages differ. The speed goes up to 12Mbaud.
All this info is to be found in the various links in the search Mickey proposed, but you would need to put some effort in to get this result.
prabhakaran1012 said:
can anyone explain in simple???
No. Unfortunately this is Siemens stuff. Simple explanations of Siemens stuff are about as hard to find as the explanation why the big bang occurred. They use to do their stuff in their own mysterious ways.
I always thought PROFIBUS = PROcess FIeld BUS ?
Could be. But my contact at Siemens Belgium called it professional field bus. Maybe he was wrong ;). But then salespersons use whatever they can to get their stuff sold, even wrong information.
Kind regards,
I have a customer that wants us to use a S7-400 PLC. I don't get into Siemens too often (unless I have to). This machine doesn't do much and...
4,993
Hi to all How many of you have had to replace a still working hmi with a different model in a system without having sources? Well, in my...
2,966
Hi, I have a new Siemens 400H-CPU. On the rack there is a power module, a CPU and an ethernet card. I need to download the hardware...
1,992
Hello everyone, I have S7-300 PLC connected to HMI pannel with Profibus. I bought a USB/MPI+ cable from ebay, now this cable does not support...
4,985
hi all, i would appreciate any help on the following. 1.how does the master check for(enumerates)the available devices on the bus. 2.how does...
2,140
