ACADE wire numbers
Not sure what version you have (mine is 2011). The command is AEPLCWIRENO. the button should be in the same group as the "regular" wire number tool.
  • Select your wire number format. You may have to play a bit to get the results you want. I had to try a couple different ones before I got mine...
  • Select the I/O module to process
  • Select wires
Here's a quick video.
I have a new pc. After I install Autocad Electrical, how do I load my projects from my old pc?
2,800
If so what are your thoughts on it? I just downloaded my update to ACADE 2015. So far with each successive generation I've grown more frustrated...
2,430
I'm looking to buy a new Dell Laptop, and thinking about the 64 bit system (Windows 7 Professional). I know that some of the older automation...
3,462
Does anyone have experience wiring this type of analog pressure transmitter up? It's 4 wires. 3 blacks and 1 green which I assume is earth...
294
Hi everyone, I need some help I new with omron plc. I using plc CP1L. When I do the program it's good and the plc is function as program. But when...
90
