Accessing a Drives Parameters via PLC using CCW [Rockwell]
Aug 2017
Joburg
23
Hi techsperts!
I was wondering if anyone could help me...
I have a project where I've configured a (Micro850) PLC
as well as a (Powerflex) VSD
They both work fine and coms is 100%
I just cant figure out how to get access to the Powerflex's tags when using Connected Component Workbench!
In older programs you would just select controller tags and all the info would be there! How do I access the control information in CCW?
I've tried looking everywhere and it seems the only place I can see the info is manually under parameters... I need that info in the PLC
Any advice?
(I've attached a Screen capture of the setup)
There isn’t a native per say way to view parameters like you can in logix5000.
Although, there are function blocks that you can use to control the drive and set parameters. The Rockwell website has some sample code on how to achieve this.
I know I’ve seen function blocks for controlling the Powerflex755s just because I am going to be doing one soon. I want to say they also had the Powerflex 525s as well.
At first glance, the function block is handling all the comms.
197
For the past few day, I have had problems accessing the Rockwell Knowledgebase. When I try to access it (and I do have a TechConnect Support...
420
Hi, Small issue i've really been beating myself up over today. I've been working with Panelview panels for years. Currently working on an older...
596
Dear experts, I have the following setup: CPU-313C (6ES7313-5BF03-0AB0 V2.6) + CP343-1 (6GK7343-1EX30-0XE0 V2.0) communicating with Siemens PC...
2,734
I'm looking to replace an AB PanelView 600 2711-K6C2 HMI with a C-more EA9-T10WCL. The PLC in the system is a SLC 5/03, which is staying. I...
1,255
