Activation Corrupt - Invalid Serial #
dataglyph
Feb 2003
Toronto, Ontario
I have installed various RSLogix software titles and they run fine as long as the Master key is in the floppy drive, however I cannot move them to the C: drive. I had or thought I had no activations (corrupt) on my drive since I recently reloaded XP Pro and changed from Fat32 to NTFS. I have been told that my previous activations are still present and corrupt, and this is the reason I get an error and cannot move my new activations. I maually deleted evri.sys and 386SWAP.PAR but this did not help. Can anyone tell me how to identify these supposed activations in the registry so that I can delete them, after which I am told I should have no problems? It should be noted that I have had no problems when I loaded these software titles and ativations on a different machine. Any help would be appreciated.
Thank you very much, in the bulliten 2 other files were mentioned (evicom.sys & icom.sys), when I searched protected files and folders I found evicom.sys to be present and deleted it. As well I searched the registry and deleted all entries for evri.sys, 386swap.par and evicom.sys. I can now move my activations on and of the C: drive at will.
James
dataglyph,
The ev in "evicom.sys" probably stands for "EverLock". EverLock is a program that Rockwell has been using for years to protect their software. I have seen ads for a program called "NeverLock". Enough said!
Hey, I just bought a new LG notebook and the activation for RSLOGIX 500 will not move from the USB Key of Floppy drive to my C: drive...
5,183
Hello, Anybody with useful information on how to regain my RSLogix5 activation key (Activation file corrupt invalid serial number) You can...
5,099
Hi Folks, who know why after start FactoryTalk activation manager V4.03, click "Get New Activations", it displays Is not I appreciate with any...
90
Rockwell Tech Support seemed to have hit a wall with this question. Already updated the version to 5.00.13 per their suggestio but am still...
271
Hello guys, I would need some help. I have installed the aveva plant scada and want to run a project. From the configurator, all are fine, as I...
126
