activation key can not returned to masterdisk
I think the laptop drive has activation file which is corrupted. tyr in some other drive in laptop ensure no rockwell software is running
Hi Praveen,
RsLogix working fine when I put USB flash drive, but activation not move. In my Laptop have only one drive. No activation of mine corrupted. How I processed ?
Riyaz
Yes, you may have accidently copied an unusable version (or already have it on the disk) of the key code EVRSI.sys onto the place where you are now trying to move it to. Check the destination drive for a previously existing version of EVRSI.sys. If there is a copy on there (non-working copy), then that file can cause the error message you are receiving. Then if found, delete EVRSI.sys (only if you have no other stored key codes for other Rockwell programs).
Note that the EVRSI.sys file will not be visible unless you have your file browser (Explorer) set to view hidden and system files.
There should be no other changes required for your computer.
Make sure you still have the good copy of EVRSI.sys on the source flash drive, before you delete the destination file bad version.
I searched for EVRSI.sys file on my Laptop's drive, file not found, can anybody help me by replaying where this file is reside, I mean in which folder.
Riyaz
It normally loads to the root directory of the drive. If you don't find it there, then something is preventing it from being moved. Screen-saver programs and anti-virus programs can do that. I always de-activate those before running EVMove.
Riyaz
This may explain why you can't find the EVRSI.sys file...
This may not apply to you, but the way our IT group sets up accounts we can not see hidden files. We can click the option to show hidden files under Folder Options, but we still can't see them. I have a local admin account for installing software, I can see hidden files when I'm logged in on that account.
Corbis,
Thank You for inserting the EVmovecf file, worked perfectly from floppy to flash drive on xp pro desktop to a xp pro laptop from flash to c:
Helped me out of a very tough spot, thank you again!!
EvMoveCF moved activation to great bitbucket in the sky
Set EvMoveCF to move from C: to flash drive E:; seemed to run normally. When I moved flash drive to second computer and ran EvMoveCF to move from flash drive E: to C: - activation file not found. Went back to first computer, it is no longer activated. Tried to use EvMoveCF to put activation file back on original computer: activation file not found.
Now I have no activation. Boy, this is some Byzantine licensing system.
You could complain about it nine or ten years ago, when it was still in use and supported and this thread started.
If you want help on the old EVRSI, start a new thread and explain which products and what operating systems you're using.
I use Rockwell Software every day, and haven't touched an EVRSI activation for six years.
Hi guys; I have a image dvd of laptop when i install it the rslogix, rslink, rsnetwork are restore with activation. If i move this activation key...
5,310
I have a older version of RS logix 500 that will not work with windows vista nor the new 7..a friend of mine give me a copy of a newer version of...
11,333
Hi guys, Our customer has undergo a reinstatement for RSLogix 500, we've received a white envelop from Rockwell c/w a CD ROM, but when we need...
3,310
I had my copy of rs logics 500 on my laptop when it stopped working,I have had the hard drive contents loaded onto a external hard drive. I am...
1,920
Hi, I have laptop with no floppy drive (or external floppy) and need to load an RSView activation key onto the laptop. Right now the key is on a...
4,848
