ActiveX PLC driver & VB6
zf_acs
Jul 2004
Hi All,
Do I need to place text field on the VB form for every single point I want to acquire from a PLC? I would need to record approx. 1500 tags.
Thanks.
Hej.
If You just need to log the data, then there is no need for textboxes.
It is op to You, where You what Your DATA to bee stored. You can make your own variables to hold the data or write them to a file.
Private Sub SaveData()
On Error GoTo SaveData_err
Dim intFilNr As Integer
Dim strFilName As String
intFilNr = FreeFile
strFilName = App.Path & "\" & App.Title & ".TXT"
Open strFilName For Output As #intFilNr
'(You should Use a loop to save the data)
Write #intFilNr, "Data"
Close #intFilNr
Exit Sub
SaveData_err:
MsgBox Err.Description
Exit Sub
End Sub
Best regard
Jesper
Hi all, I am starting a new project and I need to access the info in a S7-400. I am newbie and know nothing about it, so I am sorry in advance...
3,035
I WANT TO communication with Q PLC BY VB,WHO HAS VB COMMUNICATION ACTIVEX,THANKS. PLC Q SERIES COMMUNICATION UNIT QJ71C24 --------COMPUTER(VB)...
6,770
Good day All, I am getting Error 1 when I try to open trends on my client. I tried to resolve the problem by creating .cab files but that did not...
1,515
I'm testing the ability to make a custom ActiveX control for PVP7 applications to be able to write data out in an XML format. With my simple...
685
I found a list of activex controls in view studio for which I simply cannot find any information on online. I don't know what they do. For example...
979
