Add REAL numbers in Logix (Compact) - odd precision
phuz
Jun 2008
Mohnton, PA
1,044
I can't say I recall ever encountering this, but when adding a decimal number to a REAL, I'm getting a strange precision.
For example, starting with a REAL value of 3.4, I add 0.4 and get 3.8000002. Next add I get 4.2000003. Why is Logix doing this? Is this a IEEE 754 format issue?
I wouldn't call it an "issue", just the way floating point numbers work.
https://www.youtube.com/watch?v=PZRI1IfStY0
https://www.youtube.com/watch?v=jg1mYsIrFPs&t=65s
Since the values 3.4, 3.8, and 4.2 cannot be exactly represented in IEEE-754, or any, floating-point binary (base 2) format, when converting to decimal symbols ("1.234567890..."), at some point the symbols must diverge from the rational number (34/10).
When adding two such numbers together (3.4 and 0.4), the combined "error" will show up in the least-significant digits.
  • 3.4
    • may display as 3.4,
    • but it is internally 3.400000095367431640625000000
      • I don't know why it does not display as 3.4000001
  • 0.4
    • may display as 0.4,
    • but it is internally 0.400000005960464477539062500
  • The sum of those two internal values is 3.80000019073486328125000000000000000
  • which will display as 3.8000002
Logix REAL format representation is 32-bit: 1 bit for sign; 8 bits for exponent; 24 bits for mantissa. The mantissa represents a number in the range [1:0b10) i.e. in the range [1:2) N.B. the right side is exclusive. In binary:
0b1*0000000000000000000000 <= equal to 1
0b1*1111111111111111111111 <= slightly less than 2
Where
  • 0b => prefix indicating the following symbol is a number in binary, that is, the only available digits are 0 and 1
  • * => a "binal" point i.e. a binary analog to a decimal point,
    • so,
      • in decimal i.e. base 10: (15 ÷ 10) = 1.5
      • in binary i.e. base 2: (0b11 ÷ 0b10) = 0b1*1
        • N.B.
          • 0b11 = 3 (decimal)
          • 0b10 = 2 (decimal)
            • (0b11 ÷ 0b10) = (3 ÷ 2) = 1.5 decimal = 0b1*1 binary
So, 0b1*11111111111111111111111 = (0b111111111111111111111111 ÷ 0b100000000000000000000000) = (16777215 ÷ 8388608) decimal = (2 - (1 ÷ 8388608)) decimal
The exponent part of the IEEE-754 moves that binal point to the left or the right, the same way the exponent in the scientific notation representation 1.50000e3 (1.5 x 103) moves it to be the equivalent 1500.00 in non-exponential decimal symbol format.
And finally: the magnitude of the right-most bit is between one-8388608th and one-16777216th relative to the value itself. i.e. around one part in ten million i.e. 1 part in 107. So any error between the rational number expressed in the IEEE-754 binary number (0b1... ÷ 2exponent) and its decimal representation will show up around the seventh significant decimal digit to the right of the most significant decimal digit.
Caveats
  • I chose * instead of . for the "binal" point so the two would not be confused here
  • The term "binal" point is not a real word; I just use it because calling the delimiter between digit places representing values greater than or equal to 1 (1, 2, 4, 8, 16, ...) from those less than 1 (0.5, 0.25, 0.125, 0.0625, ...) a decimal point might be confusing
Dear all, I have following problem. I'm sending an SMS when i got an alarm. For now I'm sending "Temp to high" but now i want to change this...
3,901
I would like some comments on adding an Express Card/serial adapter used with a PCMCIA to Express Card adapter. I have an older Dell Latitude...
2,507
Hi, I have questions. I have Analog Input that need to put into Ignition Designer. But I don't know how to put?
143
I have just installed Studio 5000 V30.11 on my Windows 11 Pro machine. First I had an "Invalid Pointer" error that required me to update Factory...
141
Im trying to create a level indicator for water Tank i have used the ADD function while the pump is on and level increasing everything works...
33
1,126
