Hello,
Fairly new to PLC programming. Have a question in regards to a 1734 Point I/O rack and the built in tag structure in Logix Designer.
I have a rack of 12 Point I/O cards and I need to expand the rack and insert two more cards at rack index positions 5 and 8. The current cards in those slots are type A and the new ones will be Type B. I can't seem to change the card type at each slot position in the I/O configuration so I have to delete them and re-add them as the proper new type. The code I inherited sometimes directly references I/O which means any rung that points to a bit that's shifted in the rack now points to the wrong bit.
Is there an intelligent way to add an additional card into a Point I/O rack but shift all the Raw and Alliased tags along with it to not destroy the I/O mapping or must this all be done manually?
Thank you!
Thank you!
