Adding node addressing
ROBOMOTO
Apr 2011
ohio
We are adding two Motoman robots to a weld cell and I'm unsure how to get the omron PLC to configure the addressing?
I’m using device net and I was able to see the new nodes but as far as assigning the addressing to use I’m lost. If this still is to vague please let me know what info you might need.
You are still way to vague. You need to state what robot you are using? Xrc,NC, etc. What PLC? What software? Where do you see the "new nodes"? What board number are you using in the robot? How are you interfacing with the devicenet?
How can you see them? What tool are you using?
Is less like a crystal ball, but still vague..
1. Do you have the EDS files for the robot cells?
2. Have you given them node address's?
3. Do you have the Omron Devicenet Master Manuals?
4. Do you have CX-Integrator?
Omron PLC Jeff...
I am an AB guy so the configuration changed by platform. Still close but a little different.
reply
the robots are XRC and the PLC is CS1G and the software is CX-programmer. thanks for the help guys this is my first time with Omron if you can't tell so bare with me please
A little bit more information, but if you could answer these questions please..
1. How can you see the nodes? What tool are you using? CX-Programmer does not allow browsing of a devicenet network (that I know of anyway)
2. Do you have the EDS files for the XRC robot nodes?
3. Have you given them node address's?
4. Do you have the Omron Devicenet Master Manuals?
5. Do you have CX-Integrator?
Without answers, we are in a creek with no paddle....📓
I have a question about adding another panelview +. We want to add a pv+ in the shop to monitor a line. The line currently has 4 other...
1,204
I have this machine that is communicating via DH+ to a central Logix PLC. This PLC has two DHRIO modules and we are already getting data from this...
23
3,975
Greetings all! I've got a point-to-point DH485 network running from a SLC 5/03 to a Panelview 600. I want to add a node to this. My question...
3,457
Hi Everyone, Currently we have three plants running with Controllogix PLCs (L72, L73, L74). In each of these plants we have 2 FTView SE...
61
Hello, Im building project with 1756-L82ES controller and 1756-IB16S card but i cant find it when trying to add the card to IO configuration...
143
