Adding RIO Module
bsprowls
Sep 2005
Ottawa, ILL
35
I have an existing 8 position Allen-Bradley RIO rack with 3 blanck spaces. I want to add a 1794OF41 analog output module. Is there a trick to it, can it be done "hot" or do I need to shut the system down and configure it. I know that I will probablely have to write a BTW - BTR circuit to get it to work.
I have never understood how the I/O is configured using RIO. In the tree there is only the RIO module, not the racks of I/O attached or all the...
1,306
I am having trouble adding an output modules to a remote io rack on a plc5 the processor is PLC5/80E it has 6 full RIO racks and 2 3/4 racks I am...
2,924
Hello all. I have a job to add a 1794-IE8 Card in slot 5 on an existing Flex IO Rack which uses a 1794-ASB communications module, which...
3,012
What I am doing is converting a logix 5 program to logix 5000. What I am stuck on has to do with the RIO rack. I am using a 1747-ASB that is setup...
2,442
I have this machine that is communicating via DH+ to a central Logix PLC. This PLC has two DHRIO modules and we are already getting data from this...
23
3,982
