Hi all, Im an amateur of ladder diagram programming.
I have a case to program.. is something like this:
Input_A is ON&OFF for 20 times, at the same time ON&OFF Output_A for 20 times.
After Input_A is ON&OFF for 20 times, Output_A would not be ON even though Input_A is ON for the 21st and above times. Here, the max no. of ON&OFF for Input A is 20 to trigger the Output_A.
When Input_B is ON&OFF for 1 time, it reduces the no. of ON&OFF for Input_A for 1 time. So, Output_A could be ON&OFF for 1 time if Input_A is ON again.
When Input_B is ON&OFF for X time(s), it reduces the no. of ON&OFF for Input_A for X time(s), So, Output_A could be ON&OFF for X time(s) if Input_A is ON for X time(s).
As long as no. of ON&OFF for Input_A is less than 20, it could trigger ON&OFF for Output_A. Only Input_B ON&OFF is able to reduce the no. of ON&OFF for Input_A.
My concept is that Input_A counts and holds the no. of ON&OFF for Input_A until 20. It minus 1 when Input_B ON&OFF 1 time. And it plus 1 when Input_A ON&OFF for 1 time.
I appreciate someone could guide me to program this situation.
Thank you so much.
Thank you so much.
