Ft historian tag addition issues
edwardeduful
Jan 2015
ghana
60
Hello All,
Please I am trying to add FT live data tags to the historian.
I can add the live tags successfully, but the challenge i am facing is that some of the tags are not showing and when i try to add these tags by using individual points i can find the tags in the P-I systems management.
When i use Discover historian points and i search for these tags,and i click confirm points i get an alarm saying
Failed to create point on server.[122235] exceeded point count allowance for point-source[fatal error].
The tags i want add are just five tags and the historian is supposed to have 250 tags space, but the Alarm keeps popping up.
Please your contributions will be much appreciated.
Hello rdRast,
Please Attached is the screen shot i took when locating the points.
Kindly help me out if its ok or its not seeing the license.
Thanks,
It's been a while since I had to look, so I can't remember exactly - but I believe somewhere in your FT Administration Console you can look at the license details, and it will tell you how many tags you have a license for, and how many of them are used. Perhaps you already have 249 tags used?
I have a bunch of tags in Historian/VantagePoint that off by one decimal point. I looked into the HMI displaying the same number, and the HMI is...
120
So I'm trying to make a tag I created in WonderWare Historian display the correct tag values on the inTouch client but it is currently showing...
1,575
Hi. I have a strange issue with Points added to the Historian where they update for 1 minute and then stop updating for a period and then start...
1,371
I have a Wonderware Historian with license tag count of 5000 IO tags. The Number of licensed tags in the database is 4993 tags. Which means I am...
4,484
Using WonderWare, InTouch Windowmaker and GE RX3i PLC: Using a condition script, I created a 15 min average of an instantaneous reading and...
1,670
