Addresses needed for Micrologix 1400 built-in analogs
Here is my code
The file you posted has no analog expansion modules. If the processor is as you posted is a 1766-L32BXBA then the only analog inputs you have are embedded on the processor it self. See picture below for their addresses. Same as I posted in post #7 and Ron's #9
Maybe select the appropriate base so the stupid software knows what's going on???
johnmck66,
Here's how if you need help with that.
Under I/O configuration, select the processor and click on Adv Config.
You don't need to do this but it makes the data file I posted above look correct. The embedded analog inputs will still work without this step.
Check the Series/Rev/Functionality Type also. The file you posted says its a series B.
Thanks a bundle to all you guys, it is looking like I have a better understanding of the addressing. I will try a routine in my processor for real tomorrow.
The last 15 years have been exclusively working on Siemens, so got rusty on Rockwell..Doh!
Cheers John M
On the controller itself:
Your digital inputs are I:0/0 through I:0/19
Your digital outputs are O:0/0 through O:0/11
Your analog inputs are I:0.4, I:0.5, I:0.6 and I:0.7
Your analog outputs are O:0.4 and O:0.5.
On the expansion I/O:
Digital Inputs are I:1/0 to I:1/15, I:2/0 to I:2/15, I:3/0 to I:3/15 and I:7/0 to 7/7
Digital Outputs are O:4/0 to O:4/15, O:5/0 to O: 5/15 and O:6/0 to 6/15
Hope this helps.
David
How about Micrologix 1000 Micrologix 1100 and expansion module?
Thanks, Wilkerson29847, for your detailed answer to my original post.
I'm currently working on replacing a Micrologix 1000 (now discontinued) with a Micrologix 1100 and expansion module.
Could you provide or tell me where to find similar I/O mapping information for those two controllers? I have not been able to find it.
Found MicroLogix 1000 image file layout - still need for 1100
The User Manual 1000_1761-um003_-en p.pdf conveniently displays the information on page 5-2 under the heading I/O image. (See attached)
Unfortunately, no such REALLY HELPFUL table is in the MicroLogix 1100 manual.
Can someone please tell me how the I/O image files are mapped for the MicroLogix 1100?
Micrologix 1100 addresssing
Thanks, I did see that page. It's just not clear to me how to translate that to actual addresses. The nomenclature has to be very specific and it's been many years since I worked with it.
Hello to all, Is it possible to export Codesys symbols to .txt, .csv or .xml in a similar manner like exporting symbol table in STEP 7? For...
135
Hi guys, so I'm using BOOTP/DHCP tool in my virtual machine for setting up an IP addresses for basically everything. My only issue is always with...
370
Hi. I'm doing an upgrade of an old 1400e to a new panel view plus 7 standard using ftv studio v 12,which will be communicating to a slc 5/04 via...
2,634
Trying to find the proper documentation to explain the CC-Link Parameters for Mitsubishi remote I/O. The system I am modifying uses several...
354
Besides using BootP in the past, I am relatively new to having to look for privately addressed devices in many control networks. All of the...
23
3,974
