Adjust Ip address on AB factory talk HMI and compact logix
davidlec
Jan 2010
leicester
Help!!
Can some one please tell me how to change the ip address on a AB CLX and factory talk HMI. I am trying to change the ip address so the machine works on the same ip as other machines in the factory. I have gone to CLX properies and changed this to the new address and changed the panel view address on the configuation screen of the HMI. But the HMI cannot find the Tags of the PLC. Now when I revert them back to the original settings, the panel view still doesn't see the Tags (GULP:oops:). I am not a fan of AB and therefore do not know very much about them but I thought if I downloaded the original programs everything would revert back to the original setting (NOPEo_O)
PLease Help:geek:
There are 3 things you need to change.
You need to change the IP of the CLX, The IP of the Panelview+, AND THEN you need to change where the PV+ is looking for the CLX.
That last part is done in FactoryTalk View Studio, open your application and head down to the RSLinx Enterprise section and choose communication setup. Change the existing shortcuts for Runtime to match the new IP addess you decided on for the CLX. Then create a new runtime application and upload it to the PV+(don't overwrite the old one). Load this application and replace the Communications as it asks.
Hello Gents, I have got a request to stop the system at fixed times through the day (at End of Day/Night shifts) which could be done using the...
946
Hello all! This is probably a silly question but, hey, I can't figure it out. Is there a way to adjust the order that the pens are displayed...
1,631
Hello guys, I use Tia Portal V16. What is the best way to change the indexed HMI tags when I change the format of an Udt in my plc program...
1,313
Good Evening , After running for 2 years , I have a few Powerflex 525 drives faulting out with a F 73 Ethernet Fault . What have you guys...
2,600
Hi all I thought I had this working but upon doing a checkup a few months after the machine was commissioned, I found that adjusting the RTC via...
1,873
