Advanced Alarm setup in CitectSCADA 2015
Mariner4
Apr 2023
Oregon
Hello everyone! I have a question about the allowable syntax for an expression in CitectSCADA. If I wanted an advanced alarm to trigger based on the logic in the attachment where variable F is the alarm, could I write the expression as in the top of the picture? I am really wondering if double parenthesis are allowed. Any insight or help with this would be greatly appreciated.
Preface, I have no experience with CitectSCADA at all. I don't see a NOT on E, so is <> the proper syntax rather than =? I would think it would look something like: F = E AND ((A AND B) OR (C AND D)). Again, no experience here, just spitballing.
MikeyN, thanks for the response. The expression is currently written as E <>1 AND ( A OR B ). The alarm works as written and has been for years. I just want to change the logic to. E<> AND (( A AND B) OR ( C AND D)). I am just not sure if the double parenthesis is an allowable syntax in CitectSCADA. I have looked through the other 3000 plus alarms in the code and can't find any instances where double parenthesis are used and I just want to make sure before I make the change. In my mind it seems fine but programs can be funny sometimes.
I've created a couple of alarm lamps (M568 & M569), which light up as expected. However, I should be getting a message on the screen (there is a...
1,613
Hi, I am wanting to generate an alarm in the HMI if comms to the PLC is interrupted for any reason. I know I can use system diagnostics, but...
1,255
I have read many ways of how to use scripts to log alarms to the hard-drive or MMC card on a MP270 and Runtime systems. But what I can't find is...
23
6,914
Hi folks, I'm not as accustom with Siemens & WinCC, however I've been asked to increase the amount of data an existing application is logging...
78
Hi, We have upgraded our laptop which includes Windows 11. It appears that WinCC flexible 2008 advanced does not support Windows 11. What...
288
