advanced hmi instance error
zze110
Aug 2017
USA
Greetings,
New to the whole OPC thing so...
I have installed kepserver ex on a computer and wrote a quick test app using advanced HMI that grabs a integer tag from kepserver using OPC and displays it on screen.
If I run the test program on the same computer as the OPC server, it works.
If I run it on a different computer across the network, it says 'object not set to an instance of...' and the program doesn't work.
Also I tried matrikon OPC test and I get similar results. On OPC server machine I can see all tags. Different machine I get a connection failure.
What am I doing wrong? Thanks!
OPC can be quirky.
The number one reason for OPC connectivity problems is the clients computer firewall settings and the computers DCOM settings.
Do a google search on those topics for more info.
perfect! that link solved it. I needed to setup DCOM permissions. Working great now! Thanks!
I’m new to plc programming and very new to HMIs. So this is what I have done so far: I bought a micrologix 1100, I used bootP to set the up...
17
1,703
So I installed advanced hmi and grabbed an ethernet cable. I have the click C0-12DRE-1-D PLC. I installed the advanced hmi and added the...
2,070
Do I use the ethernet port on the click plc to connect it to my computer. Will advancedhmi work properly? Am I able to start data logging into a...
946
Having a hard time getting the data received when using BeginReadMultiple. Not the most familiar with the ClxDriver and EthernetIPforCLXCom()...
2,334
I am in search of a non-PC based, non-SCADA based HMI and software that allows the ability to dynamically draw graphical objects on the screen to...
5,050
