advanced hmi to plc response is maddddddd slow
khewes
May 2016
New Hampshire
123
hello everyone,
I created a program that allows me to control ten timers total using memory and hmi inputs. when i press my hmi inputs, it takes forever for the plc program to read that the input has been pressed. is this possibly because i have so much memory that it is lagging my processor? any ideas?
What PLC are you using?
What is the PLC scan time?
What is the communication protocol?
ML1000
using advanced hmi 399a with visual studios 2015
emulation right now not even hardware yet
DF1 com simulator rs logix micro starter lite
idk scan time where do i find that?
I just stumbled across an entire slue of non existent addresses im going to start there.
yeah there were at least 100 unused addresses, I opened an old file on accident and been working on it all morning, without those addresses is runs flawlessly.
So I installed advanced hmi and grabbed an ethernet cable. I have the click C0-12DRE-1-D PLC. I installed the advanced hmi and added the...
2,065
Hi, I have developed a small PLC program of few motors, PB, and a tank. The communication between HMI and PLC is Modbus TCP. While I was trying...
2,342
Hi , Does anyone know if you can have 2 plc's connected to your computer via 2 seperate comm ports and use Advanced HMI, with controls on the form...
4,001
I’m new to plc programming and very new to HMIs. So this is what I have done so far: I bought a micrologix 1100, I used bootP to set the up...
17
1,681
Do I use the ethernet port on the click plc to connect it to my computer. Will advancedhmi work properly? Am I able to start data logging into a...
943
