AG_SEND AG_REC via S7 LEAN and S7-319F
collinsd70
Feb 2014
Swindon
194
Hi All.
Can anyone clarify whether I can use the AG_SEND/RECIEVE blocks between my S7 LEAN Card (via a 318-2 CPU) and a S7-319F 3PN/DP?
There seems to be a lot of mixed reviews or whether these can be used on an ISO-on TCP or whether the TCON, TSEND blocks should be used instead.
Regards
Daniel.
Use ag-send on the side with the 318 and the lean card. If you are using the built in interface on the 319 side you have to use tcon,treceive.
Built in interface = tcon,tsend,treceive
CpCard = netpro,agsend, agreceive
You can use agsend on one side and treceive on the other side
Hi All.
Regards
Daniel.
My understanding is that you have to use AG_SEND/AG_RECV in the comm cards, and the T_Send family with the integrated Ethernet interfaces. They are theoretically compatible, I think, but I'm not 100% sure if special settings are needed on either side for them to work.
Hello everyone, I have an older S7 315 CPU that has a 4-port ethernet switch on it that talks to an industrial PC/HMI (old, unknown software on...
1,787
Hi, I have an S5 project that sends data serially to our production system. It uses a mixture of fb120, fb121, fb126 and fb127. The blocks...
2,396
Hi, I successfully connected to a S7-1200 and can send receive data between the computer and the PLC by using the send/receive blocks. Now, I...
4,972
So I had an odd request from a customer for the above. I have written the logic and tested it all in one PLC with only using 7 outputs and 7...
437
can the slc500 5/05 send a email and text over Ethernet ?
190
