Alarm History from Fanuc R-30iB for Ethernet I/P
Jul 2017
San Bernardino, CA
I want to be able to read and show 5 latest Alarm messages from the Fanuc R30-iB robots to an Indusoft Web Studio 8.0 HMI. Does anyone have experience with this. I can program the Fanuc with the programming pendent. The Robots are communicating with Rexroth MLC45 using Ethernet I/P already. Can I add the alarm messages to the data exchanged between the MLC and the robot?:unsure:
I configure the robot user alarms to digital outputs that are inputs to my plc. Then my PLC just triggers the alarm messages along with all of the other PLC alarms.
I've read about reading the actual teach pendant alarm message directly but I've never done it.
I've never implemented it, but I researched using Ethernet/IP to get Fanuc error messages for a customer several years ago. I don't have any experience with the Rexroth system, so I'm not sure what is possible on that side of things.
The Fanuc Ethernet/IP Setup and Operations Manual (MAROC77EN01101E Rev H) has the information you're looking for.
You have to use explicit messaging, but you can get what appears to be all of the information that is displayed on the teach pendant.
You can get the last 5 active alarms or the last 5 alarms in the history. Each of the 5 alarms needs its own message or messages depending on which data you want to transfer. There is a total of 228 bytes of available data for each alarm, but you can pick and choose. They provide everything from alarm code to the readable messages.
My access to Fanuc's documentation is on their password protected website, so I can't send you the document, but I can help you through the explicit messaging parameters, if needed.
Thanks for the responses tspisak, and Picklemon, both seem to be viable options. I have a Ethernet connection with the Robot and the RexRoth PLC that is exchanging 16 input words and 16 output words. Is there a way that I can map the error message text to some of these Inputs?:unsure:
I am doing this via explicit messaging with a CompactLogix PLC but I will have to get the specifics for you tomorrow. I'm not sure it will give you what you want, but it's something.
Here is my message configuration. This particular message captures the top-most alarm message. For each of the previous four, simply create another message instruction, use the same values except change the "Instance" value from 1, to 2 - 5, respectively, and then assign a unique STRING storage tag.
I am building a development PC. I've installed service platform and loaded a known working intouch app. On the same PC, I have installed RSLogix...
527
1,803
I'm using a GT1275 HMI with GTDesigner3 and am trying to add some Alarm Logging capabilities. I've made an alarm page and have it working...
443
PanelView Plus 7 Perf I would like to upload the fault history from the panel to the PC, if it is possible to transfer the file to CSV format or...
806
We upgraded our systems to FactoryTalk Service Platform 6.31 and ran patch roll up from Dec 22 after software updates. We have a network...
1,459
