Hello all,
I have a ControlLogix controller with an Ethernet/IP module installed and communicating with an iFix HMI. The Ethernet/IP module ( 1756-ENBT ) sends data to the HMI, such as alarms for example. We see the tag data in the HMI alarm logs with their corresponding timestamps ( Time at which the Binary Tag changed state for example).
My question is, where does the timestamp come from? Is the ControlLogix PLC time-stamping the data, is it the Ethernet/IP module, or is it the iFix HMI SCADA software?
The HMI alarm logs also display alarm data received from DNP slaves, but when I compare the timestamps between data received from DNP slaves and Ethernet/IP sources, the time seems off by a few seconds or so sometimes.
Thanks in advance.
Thanks in advance.
