Allen Bradley 1756-OF8/IF16 Wiring help
Shane.platt
Jun 2017
Tucson AZ
19
Hello everyone!
I am having some issues wiring 3 Proportional valves. I am connecting the valve position reference to a 1756-OF8 AB card in a ControlLogix L55 and using a 0-10vdc analog signal. The valve position feedback is also a 0-10vdc analog signal going to a 1756-IF16.
My confusion is that the valve uses a common negative(-) connection for both analog Input and Output. I wired the valve's position Reference(+) to VOUT and the valves(-) to the RTN on the 1756-OF8. The valve's position Feedback I wired to the IN(+) on the 1756-IF16. I was thinking both cards RTNs are internal connected.
So when I gave #1 valve a 60 degree position reference from the PLC, the valve moved to that position and I received the corresponding feedback signal. Now this is where I get confused... When I gave #2 valve a 90 degree position reference, the #1 valve's position reference went from 60 degrees to 45 degrees and #2 valve only opened to 45 degrees. Giving the #3 valve a 90 degree reference all the valves moved to 30 degrees. It appears that the voltage signals are being divided?!?
Can anyone help me out here?
Thanks,
Shane
363
Hi all, installed on chassis A17 an A/I from Allen-Bradley , problem is what ever I do , all channels are sticked on value 39.9 and cannot change...
145
I am using Allen Bradley PLC 1756-L81E and EIP module 1756-EN2TR for Ethernet/IP communication. My communication works fine but in Get-Attribute...
210
Dear All: I have the flashing red light on the FDBK indicator. The manual said that it means: The axis servo loop error tolerance has been...
640
Hi Guys, Here I have Started to work on some difficult task I hope I will get some solution here. I wanted to communicate ABB CI 840 IO Master...
911
