Allen-Bradley 1756 wiring
serpesus
Feb 2017
Pilsen
Hi there,
Maybe a bit stupid question, but I have a ControlLogix5573S with IB32 DI module installed in 1756 chassis and I am a little confused about the wiring - let"s say I want to connect a simple switch to the input. So I wire up the DC power source to the switch, switch to the input, but I cant find where to ground the power source. My question is basically where to put the ground.
Thanks 🤞🏻
Okay so now, I feel really stupid, because I tried to find any sort of pin layout for the module, but I didnt have any luck doing so. Right until now :oops:
My module didnt had any documentation about pins, when I received it, so I didnt know where the GND were located.
Still, thanks for help :p
372
Hi all, installed on chassis A17 an A/I from Allen-Bradley , problem is what ever I do , all channels are sticked on value 39.9 and cannot change...
146
I am using Allen Bradley PLC 1756-L81E and EIP module 1756-EN2TR for Ethernet/IP communication. My communication works fine but in Get-Attribute...
222
Dear All: I have the flashing red light on the FDBK indicator. The manual said that it means: The axis servo loop error tolerance has been...
644
Hi Guys, Here I have Started to work on some difficult task I hope I will get some solution here. I wanted to communicate ABB CI 840 IO Master...
916
