geniusintraining
So trying to save a little time... using the SD compact flash card on a 1769-L24ER-QB1B to several CPU's they all have the same program, can I use the SD flash to load the firmware and program? could I use a USB to SD adapter and transfer the data from a PC to the SD then just power up the L24ER with the SD installed?
Also... anyone flash the CPU's with a VM or is it to risky and use the native PC
