Allen Bradley: Cannot find 1794-AENTR in catalog to add to backplane
Or you could just install a 1794-AENT which you should be able to do in version 19 and at a later date when production allows upgrade to at least version 20.04
and change to the 1794-AENTR.
Is there a reason that you are wanting to install the 1794-AENTR, is it because you have one or are wanting to use the DLR capabilities of the 1794-AENTR.
Alan.
The project was started before I started this job. The electrical cabinet has already been built and installed.
That's why I'm more or less forced to use that module.
But anyway its my intention to get all systems updated to newer firmware versions. But I'll have to get a complete overview over the plants different PLCs.
The plant have external people available with experience in Allen Bradley, but they mostly have programming experience and not much low level hardware knowledge.
But thanks for your help. it seems so obvious now.
The official advice from AB/Rockwell is below.
  • With RSLogix5000 versions prior to v.20, Disabled Electronic Key option can be used.
    • Note: This combination is expected to work but was not officially tested.
I have been using an 1794-AENTR on a V19 Logix for over a year now without any issues. However, I am using it as a pass through to an Ethernet Solenoid Bank, and not for DLR.
Stu....
Hello, What is the Problem: I am trying to download the AOP file for the newest version of the 1734-IB8 module (ser. D 3.031). But when I select...
1,175
hi all please advise how to resolve my problem for above matter during software installation , the system detected error " Error Creating Key "...
1,452
Hi everyone! My first post, so any advice appreciated! I am working with a setup involving about 6 AB CompactLogix 5000 PLCs and 5 Wonderware HMI...
1,504
Any one give solution for this fault. We are using AB Gaurd logix controller(5573s), resent days we are facing major fault in controller...
69
Hi how's it going. Was just wondering if someone could help me out. Recently one of the guys over on the LinuxCNC forums put me onto getting an...
345
