allen bradley micro logic 1400
jimcav
Dec 2004
new jersey
229
is the ethernet connection for the 1400 ethernet ip and is it only ment to talk to other ab equipment? Can it be setup throught the MSG instruction to talk to other manufactures equipment?
Hello,
All the data I look at indicates Ethernet/IP and .... I wanted DNP ethernet.
I find these lines in the documents:
Ethernet port provides you with a programming Web server and Email capability
...an RJ-45 port for 10/100 Mbps EtherNet/IP peer-to-peer messaging
...EtherNet/IP messaging only
Hope that helps,
Mark
http://www.peakhmi.com/
This unit was removed from one project where it had perfomed nicely. Wired into simulator and we have no signs of life no LED,s lit power...
948
Hello Everyone, Hope you all are doing well. I am new to the PLC and communication protocols used in PLC. I am currently stuck with Allen...
47
13,894
Hi all, I have problem that I could do with some help with: I have a setup consisting of an Allen Bradley Micro 820 controller, Panelview 800 and...
3,064
I have an allen Bradley micro running a fan in an industrial paint mixing facility. The input fuse is 3a. The system will run fine for a bit and...
1,992
Found a couple of old unused Micro 810s with lcd displays in the miscellaneous section. Don't ever use ccw or indeed any Allen Bradley, but...
4,190
