Allen Bradley PLC data communication
marvis
Mar 2016
Italy
108
Hello guys,
I should communicate an L33ERM with firmware 30 with L35E with firmware 19. The idea is not to modify the firmware, because in L35E everything is inside (ASi, devicenet, acc ..) and I would like to avoid various problems, since the intervention must be fairly rapid.
Clearly with upgrade I could use the "product and consumed tags", but if I didn't want to opt for this path, how could I do it?
Excluding wired logic.
Is it possible to use the "msg" instruction? How?
Thanks in advance
Hello guys,
Thanks in advance
Hi, I know that some of the Rockwell processors don't have Produce/Consume capabilities, but I'm not sure which ones. Read the instruction help for details on how to use MSG instructions. Attached please find procedure for easy configuration of messaging between 2 devices. This was originally posted by JesperMP, a moderator on this forum, and I found them so helpful I copied and printed them. Hope this helps.
Hello, I am new here. I am trying to find good places to sell some surplus items that I have that isnt through ebay. Does anyone have any sources...
487
Hi good day Everyone, I have a cimplicity v10 project with 7 to 8k tags communicating with AB PLC through OPC and Rslinx classic. I have this...
267
I am using Allen Bradley PLC 1756-L81E and EIP module 1756-EN2TR for Ethernet/IP communication. My communication works fine but in Get-Attribute...
253
I have a network with 4 PLCs PLC1 is controllogix and PLCs 2-4 are compactlogix and they all need to communicate. The current way I have this...
315
Hi Everyone, I am currently trying to communicate ControlLogix PLCs via EtherNet/IP with Delta V DCS. There is a VIM2 card configured for...
342
