allen bradley powerflex 4 drive
bassboy73
Jul 2005
texas
i have a powerflex 4 drive i cant get to change to 460v input power it gets to 240 and drops back to zero cat#22a-d6p0n104
Your question doesn't make sense to me but the part number you cited accepts 480V input @ 6 amp and will drive up to a 480V 3hp motor. Anything bigger than that you'll have to move to the Powerflex 40 series.
If you mean you can't change the Motor Nameplate Volts (P031) above 240 and the drive is a 22A-D (460 V), then I would call your distributor. Either the drive is defective or it is a mislabeled 22A-B drive.
Got this new to me powered on today and have no main air and the only problem I have found is the f059 on the vfd. S1 has 24v, none on S2, and 48v...
496
Greetings everyone, I know there is a way to programmatically set the date/time on a 750 series VFD (look up Rockwell automation sample code)...
1,059
Can someone do me a huge favor and print these 2 Allen Bradley DNO files and email them to me? [email protected]...
1,771
Hi all, Client with a pretty much brand new AB Powerflex VFD starting throwing Fault 17: Input Phase Loss this afternoon. Started doing some...
9,578
We have a Powerflex 753 drive on a 192.168.1.X network that I can communicate with a Controllogix L71 with no issues on same network...
1,443
