Allen Bradley powerflex 525
Kgaraffa
Aug 2017
Jackson Ohio
Just had an interesting dilemma. 6 powerflex 525’s changed their max hertz on 5 different machines all are connected via Ethernet but do not work in tandem. What would cause the maximum hertz to change by themselves.
Do you have ADC enabled?
Are these drives added recently?
Are the DataLinks set to access the Max Frequency parameter?
Is there a MSG block setting these parameters, somewhere in the code?
Got this new to me powered on today and have no main air and the only problem I have found is the f059 on the vfd. S1 has 24v, none on S2, and 48v...
481
Greetings everyone, I know there is a way to programmatically set the date/time on a 750 series VFD (look up Rockwell automation sample code)...
1,052
Can someone do me a huge favor and print these 2 Allen Bradley DNO files and email them to me? [email protected]...
1,763
Hi all, Client with a pretty much brand new AB Powerflex VFD starting throwing Fault 17: Input Phase Loss this afternoon. Started doing some...
9,518
We have a Powerflex 753 drive on a 192.168.1.X network that I can communicate with a Controllogix L71 with no issues on same network...
1,439
