Alternate between 2 pumps
wcp83
Dec 2010
Bismarck
I need to be able to alternate between 2 pumps, wondering what is the best way to do this, using controllogix. If in auto and a start signal is sent then I need to be able to use pump1 and the next time I need to use pump2, so forth and so on.
Each time the start signal is received, alternate a bit which controls which pump to run.
There is never a "best" way to alternate a bit. There are loads of examples on here, search for "flip-flop" and "toggle" and such like.
I like to use a counter, because it is retentive, use bit 0 as the alternating bit.
Hello I hava a system that should sort pieces to three different places (today it is only alternating between two). One output sends the piece...
1,880
Hello All, I want to publish my data in sql server in Excel format as daily report. And xl reported pro version seem to be much expensive which...
496
I'm looking for alternate module that I can use in place of Rockwell 5069-IO mainly for safety output card (OBV8S). Looking at the lead time, I...
1,200
Good morning everybody, I hope you are very well. I share with you the information of the PLC LOGO! Siemens and expansions that we have...
1,097
Hello All, Currently I am migrating S7 300 to S7 1500 & I am unable to use DP send & receive data from Master PLC. Which instruction is...
1,640
