Alternate PLC5/60 to Ethernet connection
crazyau
Jul 2011
limestonecoast
Hi All,
We have a PLC 5/60 C that went down and I was able to find another, but revision H instead of P.1
Everything seems to be ok except the Enet sidecar flashes fault 37. I believe this is because the firmware in the 5/60 is not new enough.
Critical use for this plant is only a few more weeks until season finishes and then we can look to a Controllogix upgrade.
It is still working on DH+ to a Rslinx PC.
Is there a way to use Rslinx to give the PLC an Ip address so it can be accessed by the Scada system?
Else I have a 1761-NET-ENI that I maybe able to use.
If you have techconnect access, Answer ID 61405 listes the various versions needed.
That said, I don't believe there's anyway to set the IP and have it work if you don't have the right revisions. Maybe see if your local AB office will hook you up w/ a FW revision?
Just noticed that the original post implies the 5/60 is a series C. One of these technotes has the following quote:
For series C, it is especially important to have PLC-5 firmware at the latest firmware revision level. See 18946 - Enhanced & Ethernet PLC5 Processor Series and Revision Enhancement History for current PLC5 firmware revisions
I looked at 18946 and it did not seem too helpful in this regard.
As I was closing technote 4417, I realize this is the full quote:
•The below chart does NOT apply to 1785-ENET Series C
◦For series C, it is especially important to have PLC-5 firmware at the latest firmware revision level. See 18946 - Enhanced & Ethernet PLC5 Processor Series and Revision Enhancement History for current PLC5 firmware revisions
So in this context, the "series C" appears to imply the 1785-ENET, not the processor. The table following that quote specifies a minimum revision K for the PLC-5/60 series C.
Wow, Quick responses here!
I assume swapping the Eeprom chips over is not feasible either?
I will contact Local rep to see if firmware upgrade is available.
Thanks!
Hi All, I'm building a PLC5 system into my home, mostly for educational purposes, but I'm going to do some useful stuff with it. I have a desire...
3,736
Hello All, I want to publish my data in sql server in Excel format as daily report. And xl reported pro version seem to be much expensive which...
498
I'm looking for alternate module that I can use in place of Rockwell 5069-IO mainly for safety output card (OBV8S). Looking at the lead time, I...
1,205
Good morning everybody, I hope you are very well. I share with you the information of the PLC LOGO! Siemens and expansions that we have...
1,098
Hello All, Currently I am migrating S7 300 to S7 1500 & I am unable to use DP send & receive data from Master PLC. Which instruction is...
1,643
