Alternate Wiring Connectors for Kinetix 350
benaiahhenry
Sep 2011
Corning, NY
265
Hey Everyone,
I just got quoted $75 from my Allan Bradley vendor for a 2097-CONN1 replacement connector set for a Kinetix 350 drive. I know AB stuff is always expensive, but this seems a little steep...does anyone know of any alternative connectors that work with the Kinetix 350's?
Thanks,
-Benaiah
Hey Everyone,
Thanks,
-Benaiah
http://www.flexcable.com/welcome-to-flexcable/
Look for breakout boards.
I've used them a lot with kinetix series hardware.
Solid!
bkottaras is correct and our AB distributor has actually recommended these for us.
Just a heads up though, some of the encoder connectors we used did not have a way to ground the shield, so you may have to find a good way to get that done. Also, if you have an issue with noise and your AB service tech sees an off brand connector, they may tell you to replace it before they go any further.
I'm not saying don't use them, just be aware.
Solid!
Thanks for the link! It looks interesting, but I'm slightly confused as to what exactly its replacing. Is the FCBB-K3C-50-42 (link) a replacement for the 2097-TB1 (I/O Connector) and the FCBB-15-16 (link) is a replacement for the standard low profile encoder connector?
Do you know of any connectors what would work for the other functions (input/output power, STO, etc)?
Hello All, I want to publish my data in sql server in Excel format as daily report. And xl reported pro version seem to be much expensive which...
502
I'm looking for alternate module that I can use in place of Rockwell 5069-IO mainly for safety output card (OBV8S). Looking at the lead time, I...
1,215
Good morning everybody, I hope you are very well. I share with you the information of the PLC LOGO! Siemens and expansions that we have...
1,106
Hello All, Currently I am migrating S7 300 to S7 1500 & I am unable to use DP send & receive data from Master PLC. Which instruction is...
1,662
Hi guys Do you have some experiences with Power Analyzers such as Siemens SENTRON PAC4200?.. I have alternative analyzer installed on machine...
2,077
