Dustin, I will print a PDF file and post it for you. Be right back.
Here it is. Page 35 is the start of the subject Rungs 199 - 123 and Output O:8/5 Table Turn CCW.
I think Rung 122 is the problem. I:1/13 is already ON so unlatches O:8/5 before the motor can run CCW. I think the CW fix will have to be done on RUng 127 before the CCW fix can be made to work.
I don't think a counter or any other type of alternator is needed here. The logic only needs to be restored to the original and maybe cleaned up a little.
How did you manage to get only part of the code? Usually it is all or none. Was there any old hard-copy print-outs in the bottom of the cabinet?I recieved this machine in our plant and it was missing some parts and some code.
