Alternative star-delta starter arrangement.
Jesper
From another view I think there is safety problem with your circuit
You need to connect the brekers together in a way when you shut down
one the second will shut too.
Arik,
thats a very good point !
Someone could mistakenly think that the motor terminals are safe when only one of the CBs is switched OFF.
Well that decides it. I cannot recommend the idea any more.
I agree with ArikBy there could be a safety issue. If you change the way it`s been done for ever. Some of us old timers are slow to learn.
By the way I would think a Y delta starter would be considered a soft start sense it only developes 57% starting torque. Because of the low staring torque we`ve had trouble starting small chipper motors 250 Hp and less also bandmills. Sometimes it takes 30 seconds sometimes 200 the reason for the long start is that it trips the main breaker. As you know in the field you have to live with what ever the engineers design and send with the equipment.
Greetings All, I recently decided to start freelancing in Controls and Automation part time, most of my experience has been with Rockwell...
155
Recently I have requested a quote from Magnetek for their Impulse Drives but can't raise a response from them. I've requested a quote FOUR TIMES...
1,066
Hello All, Its been a long time since i've been in the trenches actually doing development. When i was developing I used PicsPro extensively for...
1,179
Hello friends, I'm asking a new question here, after thinking a lot about my problem, I wondered if it wouldn't be easier for me to install new...
736
Hi all. I'm a uni researcher using FactoryTalk Studios SE (just basic knowledge). Have some previous experience with Factory View32 years ago and...
637
