Always enable bit in ABB Codesys
You can make your own like Parky already mentioned but there's even easier way.
Just create variable to global variable list like this : AlwaysOn :BOOL:=TRUE;
Now you can access to variable from the programs by typing <var.list name>.AlwaysOn
Is that initial value or value allways at global vars.
What happens if by mistake value is writed to false on ladder side?
Thank you so much for Fast reply.
Like a system clock bits in siemens (m8000.2),do we have in ABB?
Note:No need to turn ON bit from user side,whenever CPU goes to run condition,automatically this bit(M8000.2) bit will ON.
Looked on the website, as useful as a chocolate fire guard. I suggest you use one of the two already stated unless you can find the programming and hardware manuals. If you put the code in the first rung of the cyclic scan there should be no problems.
You are absolutely right on this and i didn't thought it. Australian gave much better suggestion to this:
Or use a read only variable (constant)
VAR_GLOBAL CONSTANT
Always on : BOOL := TRUE;
END_VAR
Or local to the POU
VAR CONSTANT
END_VAR
hello I have 7cp476 cpu why can led always open and No connection
144
I have a program that I am gradually piecing together (my first program). There are 4 cascading timers that turn Y001 and Y001 + Y002 on and off...
549
So I've been told time and time again that a PID (or PIDE) instruction should never be conditionally enabled/disabled and the only thing that...
684
Found this online :hmmm: Kind of funny :) We use "Always Off" for Dummy Code to Monitor tags in the ladder to avoid [AFI]'s from throwing...
17
3,002
It seems that the OPs always want to be secretive. Not just on this forum but also on reddit/control theory and especially on a Chinese forum we...
40
9,883
