Amplitude or RMS of certain harmonic
meelman
Oct 2019
Croatia
How can I find out Amplitude or RMS
Of certain harmonic in a sine signal If I got Full THD and basic harmonic RMS value as well
Do you have access to the raw signal or do you just have the RMS value of the fundamental and the valve of the THD? From what I understand THD is simply a sum total. You won't be able to determine content from that number.
Keith
What is the base frequency, and which harmonic are you trying to analyze?
Since this is a PLC-oriented forum, it would follow that you have interest in using such technology. Is there a particular model, besides the Beckhoff mentioned, under consideration?
Dar All, I want use conreol a servo drive with s7-1214dc with pto. s7-1214dc PTO amplitude 5V or 24V? Best ragrds
1,810
Hi guys, I'm trying to configure a rate of change alarm on a setpoint tag so that when the operator types a number by error (exemple: 30 instead...
174
Hello, I have been tasked with adding some analog signals for display and alarm setup in some old Schneider Electric HMIGTO HMI-panels. I have...
189
Dear Friends, I have few Profinet slaves connected to S7-1200 over Profinet. I wish get alarms and disagnostics from the devices. (IO-Link...
164
Hello Guys, I am using 1769-L36ERMS PLC by Rockwell which doesn't let me MOV or COP literal text into string datatype? i very well know the...
404
