Analog, 24v dc, and 115ac in the same conduit
Tom,
I never meant to say that separate conduits for different voltages are not useful - they certainly will help to reduce the effects of induced voltages and EMI/RFI. My point is rather that the termination cabinets should not be ignored (as they often are) just becasue the separate conduit method is used. In some situations the benefit of the separate conduits can be nullified by mixing unshielded cables inside the temination cabinets. The deluxe method is to use separate conduits, shielded cables, and then keep different voltage equipment separated inside the control panels as much as possible. If you are separating your devices and wireways, then this is probably the reason that you have never had a problem with induced voltages.
As you said, EMI/RFI noise is peculiar. It is certainly dependent on the frequencies involved, the arrangement of the wires, size of the cabinet, and so on. At 60 Hz the problems are different than at 400 HZ, for example. I have seen reports that whether or not you should ground both ends of a shielded cable strictly depends on the frequency level.
Hey guys were having difficulties with a flow meter that takes 24VDC PSU but sends 4-20ma output as we verified. The Compact Logix analog module...
17
10,687
Hi guys, I've a field instrument (actuator) using 24V AC, 0-10V. The terminal connection as below: Terminal 1 = 24VAC Terminal 2 = 24VAC Com...
3,951
Hello every body, I have an Analog I/O card with the input signal range of 0 to 5 V, 1 to 5 V, 0 to 10 V, –10 to 10 V I want to use it with 24v...
3,559
New at this so here it goes, Could anybody give me a basic overview of what this type of FLEX I/O does, its an '8 input analog module...
4,839
Good afternoon, I am currently working with an HMI/PLC LP-a070 and I require at least one analog output, but the PLC does not have one. I was...
115
