analog control using plc (urgent request please)
Jul 2012
KUWAIT
18
hi all
i am just new to the PLC analog world and i need to do some analog programming using Omron PLC ..so i need to know some points to start with it...
Q1: is it differ if i am using the various Brands of PLC (Omron ,AB,Schnider..etc) ?or the analog programming is fixed for all.
Q2: from where should i start to study the analog controlling? (giving that i am using CX-programmer and i did a lot of digital programming on it before) .
please when explain in details because there's alot i don't know about PLC.
Thanks in advance.
The concepts are the same for every brand, but the details of implementation are different for each. Fundamentally you have to obtain the data, convert to engineering units, determine if and what type of control action is required, convert the decision to the required output info, and transmit that info to the field control device.
This is one of those disarmingly simple questions that could take a full semester course and decades of field experience to satisfy. I suggest you start by readig the appropriate sections of the manuals for both the PLC and the programming software.
I keep getting the following error message when I build my project.{Elementary Variables} : The topological variable is incorrect I'm not sure...
2,147
S7-315 I have inherited a job that someone else designed and started. It has Hydraulic Servos 0-10v from an analog OP card and Encoders back to an...
2,234
Hi All!!! It's my first post on this forum so be a patient,please. I'm writing program using RS Logic 5000 and I need have a variable speed...
19
8,521
I have an analog input device, a Rockwell ControlLogix PLC, A Bradley VFD, Logix5000 software. How is the best way to program the PLC to vary the...
7,575
I have an analog input device, a Bradley control logix PLC, A Bradley VFD, Logix 5000 software. How is the best way to program the PLC to vary...
2,608
