Analog I/P Scaling using RS Logix 5000
Ish_Yad
Jun 2016
Wuppertal
Hello,
I am a beginner in PLC Programming and FBD language. I faced problem in trying to scale a Analog Input (Temperature Sensor) instruction using FBD in RS Logix 5000 to 4-20 mA current i/p.
I want to scale 0 - 100 deg Celcius into 4 - 20 mA. I am using a 1756-IF16 Analog I/P Module.
I tried using the´SCL` instruction. I am unable view the Scaled Output. Can anyone please help me out? I have attched the program below! (Routine - Sample)
Can anyone also tell me how to Toggle bit in FBD i.e. Change the I/P status to view the O/P?
Thanks & Regrads,
YAD
I believe that A 1756-IF16 Analog I/P Module can be scaled at the card
by going to the properties of that card in the RSLogix 5000 I/O Tree.
first things first ...
it looks like your Samples routine isn't being executed by the processor ...
try going into your Cooling_Demand routine - and add an unconditional rung with a JSR (Jump to Subroutine) instruction there ... set it up to go to/call/scan/execute/run the Samples routine ...
then if you're having more troubles, post again with more details ...
TIP: it looks like you're using the Emulator software - as opposed to real-world hardware ... sometimes the Emulator doesn't work exactly like real hardware - especially with input and output signals - so keep an eye on that ...
I'm not exactly sure what you mean by that question ... this is just a GUESS ...
try Right-Clicking on IP_1 ... select "Monitor" from the pop-up menu ... that should take you into the tag listing - and you should be able to change the value of IP_1 there ...
good luck with your project ...
Hi all.m doing my FYP regarding PID control of inverted pendulum.for this first m scaling the analog input of 0-10 volts using AB SLC 5/03,NI8...
2,196
Hello Guys,Any one please tell me how to scale an analog sensor which is 0-10v and it has to be scaled to 0-8v or something using math...
3,690
Hello, We monitor the temperature of a pipe via a 4-20mA temperature transducer. This goes into DB135(Read Analog Inputs). The issue I have is the...
627
Hi all! I have a question about RSLOGIX and Analog input/output scaling So we have an existing controller with an IF8I and OF81 card. My...
935
I’m trying to perfect the HMI interface for analog configuration. I’ve provided the user the same options for all analog inputs, as follows...
1,674
