zahidraza1212
Hi all.m doing my FYP regarding PID control of inverted pendulum.for this first m scaling the analog input of 0-10 volts using AB SLC 5/03,NI8 Card.I chosed configuration as follows
input I:4.0
min input 0
max input 32767
output min 0
output max 1000
when i vary the voltage from 0 to 10 volts the input shows up in decimal 2 b from 400 to 8000.and the output shows up like from 4 to 55.i dont understand wht is the problem.i selected the Engineering units in configuration.and made the channel active that is channel 3.i changed the range from 0-10 volts.in frequency option i tried 0,20Hz.
as m using single input not differential.i grounded the shield and the IN2-.and applied the positive voltage to IN3+ using power supply directly
if expect good suggestions
input I:4.0
min input 0
max input 32767
output min 0
output max 1000
