facing problem with SMC FLEX soft starter
srinaath
May 2017
bengaluru
I am facing a problem in which when the emergency stop is pressed, the motor comes to zero speed but going to start state instead of stop state.
i have attached he wiring diagram.
"previous" file consist of my current wiring diagram!
"latest" file corresponds to correction that i would like to do. Is it correct approach?
Please correct me if the following statement is correct.
pin 18 - if low signal is given then stop command is enabled!
pin 17- if high signal is given then start command is enabled!
am i right?
Hi Friends, I am facing a problem with encoder adjustment in Sew Electric Cylinder CMS71L. encoder using is Sick Hiperface Drive is MOVIDRIVE...
17
791
Hi everyone, I am facing a problem with my F5 series KEB Frequency drive. I have cobivis5 software and HSP5 service cable for interfacing. i am...
2,101
I'm working in Schneider PLC platform and not aware of RSlogix. In my new project I need to communicate my Quantum PLC with 1756-L55 controller...
1,699
I'm trying to interface plc and scada where scada is monitoring and controlling the parameter using MODBUSA3 protocol but SCADA is not sending 05...
1,696
hi , Friends I am facing problem with wonderware InTouch in which the tags which are used for alarms is showing the date time of 01/01/1970...
2,654
